How can you use something that doesn't exist? My GitUp cameras didn't come with chargers, just USB cables.I have readed this issue many times, but there's always a common factor: users not following the manufacturer recommended charging method.
I believe this low quality batteries can be damaged easily using chargers and powerbanks (depending of its output power). Probably many people can say this doesn't damage the batteries but i disagree, everytime people faces battery problems they say they used powerbanks or external chargers (not from manufacturer). For me it's not coincidence.
While i have my Git2 i never faced this problem and i always charged using PC USB 2.0 method.
If you don't follow the rules, don't blame then.
normal temp. Around 28 degrees
Guess what, I switched over from a 1A charging port to 2.4A charging port on my USB charger hub and it was able to charge it fully! Will need to do a few more tests to confirm. Will update. Thanks.
Also possible that chargers have falsely advertised output numbers... So one possibility is that the "1A" port being used at first wasn't delivering 1A, and the new one is either actually delivering up to 2.1A or is just providing more steady power than the other...
Another possibility is the first charger is dying and can only provide enough power to put half a charge on the battery before it quits working... One way to test would be to try charging with the old charger for about 2 hours, then unplug the charger from the wall and wait an hour or two for it to completely cool down then try charging again and see if you get more juice into the battery.
It require less 1A for charging, we recommend charge the battery via connecting the camera with computer, and turn off the camera while charging.
It will not be charged unless if it is too hot.
The battery factory we worked with is a not a small factory, they have lots of experience for battery production, they also supply battery for military and industry.
Recently I got an action camera sample from another factory, it is even not allowed recording while charging due to avoid over heating for battery.
Yes the supplied cable is not the best one, it does the job but you get better charge performance with better ones. It's important to look at the AWG thickness stamped on on it, the lower the number, the better.
