I guess my question is for installing without a fuse tap and using the built-in connector as shown in the original picture. Are some fuse slots given more current/power than others? I just want to plug in the built in connector to an empty fuse slot (next to the 30A fuse) just to test it out but worried that slot might have a high current output and it'll blow up my hardwire kit immediately.
Short answer:
You can test it, nothing will blow up. All fuse slots will be 12 Volts which is what you want. Current only supplies what the dashcam wants.
Electricity will only give the amount of current required for the device. If the device is faulty and attempts to draw excess current(Amperage) the fuse will blow.
If you have a normal car then you will have 12 Volts. Very old Volkswagon had 6 Volt systems and trucks use 24 Volts.
Cars are 12 volts.
You can use any fuse to tap the 12 volts. You may not have noticed but many of your empty fuse slots don't have both sides of the connectors. The fuse box may be used in many cars so not all fuse slots are required.
The other thing you need to keep in mind is that the Red wire has to go to a fuse that always has power. With everything off in the car, the ignition key removed then you poke around for a fuse that always has power.
With the yellow wire, you need to find a fuse that only has power when the car is on or in accessories. This is how the dashcam knows when to go into park mode.
The last wire - Black wire, make sure it is connected to a metal part of the car. It is really important that it is connected firmly.
The interior cabin light might have constant power. Easy to check - close all the doors, lock the car with you in it and the ignition key removed then switch on the cabin light. Find that fuse and pull it out. If the light goes out then it might be constant power which you would put the red wire fuse kit onto. I say might be because some cars might disable the cabin lights once the car is locked or a timer enables.
The accessories fuse should be easier. The cigarette lighter may only have power when the car has the ignition on. Of course, if the cigarette lighter works when the car is off then you will need to find another fuse.
Another way to work out what fuse is on or off is using a probe. Here is an example of one.
Car probe You could also use a Multi Meter set on DC voltage.
Low Price Multi Meter.
