Tanckom
- May 1, 2016
- Germany
Hello people, so I'm not sure if anybody tried it yet, however i might have found the white balance!
The command which changes it is:
t ia2 -adj awb [] [] [] [] [] []
And i was tweaking around with some values in the [] brackets, however didn't figure out yet which number is used for which purpose. But one thing is sure, it changes the white balance!
Test 1:
t ia2 -adj awb 0 0 0 0 0 0
t ia2 -adj awb 200 200 200 200 200 200
t ia2 -adj awb 200 0 0 0 0 0
t ia2 -adj awb 0 200 0 0 0 0
and with
t ia2 -adj awb 0 0 200 0 0 0
and with
t ia2 -adj awb 0 0 0 200 0 0
and with
t ia2 -adj awb 0 0 0 0 200 0
and with
t ia2 -adj awb 0 0 0 0 0 200
Which means the first value needs to be the White balance.
However, the other values are playing a role too, as you can see with:
and
They both have the greenish look, but the second seems to be darker.
Test 2:
t ia2 -adj awb 4000 200 200 200 200 200
t ia2 -adj awb 100 200 200 200 200 200
t ia2 -adj awb 4000 0 0 0 0 0
t ia2 -adj awb 100 0 0 0 0 0
Test 3:
t ia2 -adj awb 6000 6000 6000 6000 6000 6000
t ia2 -adj awb 6000 0 0 0 0 0
and with
t ia2 -adj awb 0 6000 0 0 0 0
and with
t ia2 -adj awb 0 0 6000 0 0 0
and with
t ia2 -adj awb 0 0 0 6000 0 0
and with
t ia2 -adj awb 0 0 0 0 6000 0
and with
t ia2 -adj awb 0 0 0 0 0 6000
Test 4:
t ia2 -adj awb 6000 5000 5000 5000 5000 5000
t ia2 -adj awb 6000 4000 4000 4000 4000 4000
t ia2 -adj awb 6000 3000 3000 3000 3000 3000
t ia2 -adj awb 6000 10 10 10 10 10
and with
t ia2 -adj awb 6000 20 20 20 20 20
and with
t ia2 -adj awb 6000 60 60 60 60 60
and with
t ia2 -adj awb 6000 100 100 100 100 100
and with
t ia2 -adj awb 6000 150 150 150 150 150
and with
t ia2 -adj awb 6000 200 200 200 200 200
Test 5:
t ia2 -adj awb 1000 0 0 0 0 0
t ia2 -adj awb 3000 0 0 0 0 0
t ia2 -adj awb 5000 0 0 0 0 0
t ia2 -adj awb 9000 0 0 0 0 0
Conclusion after 5 tests:
t ia2 -adj awb a b c d e f
Value a: Either setting white balance level, or some color/level value.
Value b/c/d/e/f: some other changements
However haven't fined out how the values are matched to the lightning.
(p.s. this is inside my room, currently its dark outside, so its not sunlight, but light from lamps).
So, if anybody want to do more tests, to help me to find this WB setting, please do that!
CONTINUES HERE ---> https://dashcamtalk.com/forum/threads/update-2-white-balance.19354/
Test 1:
and with
and with
and with
and with
and
Test 2:
Test 3:
and with
and with
and with
and with
and with
Test 4:
and with
and with
and with
and with
and with
Test 5:
