Updated Innovv GUI
parklawn
Sudbury, Ontario
DR32. Innovv C2, C3 A118C
You might be pleased to know that 2KOOL4U.com has released an update to its Innovv configuration utility. I have found that this is the easiest way to make changes to your settings and preferences, and also to update
your firmware.
http://www.2kool4u.com/minicams/keychaincam1080_720P_C1.shtml
Ez Configuration Update 01-16-2015
#1 App will no longer auto check for updates, you will need to manually
check for updates using the updates tab.
#2 You can now download any firmware more than once. Previously you
could only download the firmware one time.
Firmware Update 12-11-2014
Firmware C3 Camera
#1 USB connection improvement.
#2 Connection TV and auto recording.
#3 SD card reading improvement.
Ez Configuration Update 10-26-2014
#1 Firmware C3 camera.
#2 Added setting for Time Lapse Video C3 camera only.
Ez Configuration Update 10-1-2014
Ez Config used a 1 year certificate and it expired. Once expired it can no longer be updated or modified.
New app was created with new 1 year certificate.
Firmware 3-10-2014
Firmware C1 C2 Cameras.
#1 Decreased G-Sensor sensitivity.
#2 Engine stopped / DC power removed, camera will save video and shut off.
#3 Manually enter parking mode as shown below.
(Press power, press shutter to stop recording, press mode 3 times, green led is blinking.)
#4 Press power and shutter button at same time to format SD card in camera. Green led will blink until format is finished. Format takes about 5 seconds.
Firmware Update 1-8-2014
#1 G-sensor setting added, OFF
Set to off disables auto rotate feature
#2 Improved Saturation
Firmware Update 12-30-2013
#1 Added more values to EV.
#2 Added TV mode NTSC/PAL.
#3 Improved One Video Recording file. size.
#4 Improved motion detection sensitivity.
Firmware Update 12-26-2013
#1 Improved the new function Auto Bright Night . (ABN)
#2 Improved the orange color under city light.
#3 Improved the brightness in day and night.
Firmware Update 12-06-2013
#1 New firmware associated with GUI.
#2 New released Video High Dynamic Range
Normal, Day, Night version.
Firmware Update 11-26-2013
#1 Redefined the video file name and protection in loop recording mode.
Normal recording, file name is L001.MOV. And can be replaced by last recording after card is full. Camera go shocked during recording, file name is LOCK001 .MOV and cannot be replaced after card is full
#2 Redefined the L00k001 .MOV file.
Camera in parking mode and camera with external power supply, when it gets shocked during recording the file name is L00k001.MOV.
#3 Improved video quality in low light.
#4 FW file will be deleted by camera after upgrading.
RockThinking
China
INNOVV C1, C2, C3
Thanks for 2KOOL4U, for sure, he is doing better than our FW guys.
We keep contacted with him for the next updating.
parklawn
parklawn
Sudbury, Ontario
New version of the Innovv Ez Configuration GUI has recently been released (Version 1.0.1.3) by 2Kool4U.com. It is applicable to Innovv C1-C2-C3-C4 and is much more user friendly, in my opinion, than the Innovv.com version.
RockThinking
China
INNOVV C1, C2, C3
Add the more settings to the firmware, and it works more stable, as attached.
Yes, can download it from 2Kool4U.com, Bob is skilled, and he has the last FW.
G Innovv Tech 3
M Innovv Tech 1
RockThinking Innovv Tech 18
RockThinking Innovv Tech 33
cf7 Innovv Tech 2
Similar threads
