I'm considering getting an A229 Pro 2CH for a recently purchased 2020 Jeep Wrangler w/ hard top. I'd like to make sure the hard top removal process isn't an issue with the rear camera wiring. My thought was to run the USB-C rear camera wire to the rear of the Jeep, to the same place where the Jeep's standard electrical connection harness runs (and has a quick connect/disconnect bracket to use when the hard top is removed/reinstalled). Then, connect a USB-C extension cable from that point to where the rear camera is mounted on the rear window.
So my questions would be: 1) Would there be any issues with performance of the A229 if I did this? 2) If not, any suggested/specific cables I should be looking at?
Thanks.
Thanks.
