Using Registrator viewer with a129 Plus
Prelude89
Viofo A129 Duo
Hi All,
I finally got my a129 Plus installed.
Loading my first video's onto my PC, I found, unsurprisingly, that the python script ("Sergei's Novatek MP4 GPS parser") I was using to extract GPS info into a GPX file no longer works with the video format.
After some googling, I found that the exiftool can produce the GPX file, so great ... until ...
It uses KM/h as it's speed values, while Registrator Viewer uses meters/second for it's speed.
It's probably a long shot, but does anyone know of a way to make it work with KM/h instead?
I could write a processing script to re-write the GPX file, but would prefer a simpler solution.
I know it's an old program, but the last time I looked, there was nothing as good as it to view dashcam footage with maps etc.
Any help is much appreciated - including pointing to alternative viewers that exceed, or at least come close to the feature set of Registrator Viewer.
Sadly the guy that made registrator viewer was killed in a motorcycle accident, so from that front there will be no updates.
The M/s sound strange, here in Denmark we only measure winds in that format, i was pretty sure registrator viewer used KMH, BUT ! it have been 10 years since i used it as now i dont use any dedicated dashcam players as i dont need to see maps ASO
Yes, it was a very sad event when he died.
As for the whole m/s and KM/h, I find it odd as well, but the numbers in the created GPX files don't lie. Using the python script generates m/s for speed, while ExifTool generates KM/h.
If there's no easy solution to be had, I might just write a script to post-process the GPX file ...
Thanks for the reply.
If anyone is interested, I've written a script that will extract and process the GPX files so they can be used in Registrator Viewer.
