pablo.gyds03
Hi All,
First post here, I installed the Vantrue Hardwire kit in my Prius, I have the yellow going to a switched accessory and the Red going to a constant power fuse, I tested the constant power with a test light to confirm that it does have power when the vehicle is off. I plugged in the fuse tap to the constant power and tested both fuses with a test light by probing the top of the fuse at both contacts and verified I have power.
The problem is, I have no power to the dascham (Vantrue E1) when the vehicle is off. I plugged in the USB C cable from the hardwire kit to my phone and no power.
Accessory is working and the camera turns on with ignition.
Do I have a bad hardwire kit?
is this a common problem?
When I get time this weekend I will back probe the bullet connector to see if I have power there. I didn't think of it until now.
