Vantrue JS3 All-in-One Jump Starter & Air Compressor - Unbox + Impression
runtohell121
Viofo & Vantrue - too many to list
Thank you for Vantrue / @Jeff_Vantrue and Wendy for sending the Vantrue JS3 to check out.
Great build quality and multi functional device; great to throw in the trunk of your vehicle.
Link to product on Vantrue website: https://www.vantrue.com/products/js3?variant=52514081931573
Features (copied from Vantrue website):
  • Jump Starter + Air Compressor + Emergency Light — All in One
  • Built-in Wireless Inflator with 6 Preset Modes
  • Smart Display with Real-Time Voltage, Pressure & Battery Level
  • 65W USB-C Fast Charging (Input & Output)
  • Ultra-Long 80cm Hose — Reach with Ease
  • Smart Safety System with 10 Protections
  • High-Efficiency Motor — Faster Inflation
  • Fire-Resistant Housing (UL94 V0 Rated)
Packaging + carrying case - nicely detailed on the packaging, listing what functions it has and comes with a nice carrying case. Within the carrying case, it has the jump starter cable, air compressor cable, and USB-C cable; nicely packaged inside and easy to access in the mesh pocket.
The display on the JS3 is easy to read. Love the large text. The large rubber buttons are also easy to press and instructions were simple. Power the unit on, press the "M" button to change inflator mode, and use the +/- buttons to change the target pressure. After the pressure is set, simply press the air inflator button and let the unit do its thing and will stop at the targeted pressure. Also nice to have a bright light that can switch between white and red as well as change to flashing if needed by simply pressing the light button to switch between modes.
Having a 65w in/out through USB-C is great! Can fast charge many devices such as my MacBook Air 13, iPhone 17 Pro, or Samsung Galaxy S26 Ultra; and many more! Also being able to charge the JS3 with higher power is nice. It would been nice to come with a USB-C car charger or house wall charger.
Video of the inflator inflating the tire - takes about 1 minute for around 6-7psi:
I have yet to test the jump starter function (luckily) as none of my car needed to be jump started. My current vehicles (Tesla Model Y, Ford Maverick Hybrid, Mazda CX-90) are probably too new and doesn't need to be jump started. The inflator works perfectly, the flashlight feature is quite useful, and the USB-C charging is great!
