rvfoo
- Aug 1, 2016
- Street Guardian - SG9665GC
I just received my SG9665GC, which is intended to be mounted in our motorhome. The windshield is pretty much vertical and I selected this model due to specs and partially due to the "vertical windshield, no problem" comment in the product description. I might still be missing something; but I'm not quite sure it's really suited for vertical windshields. The thicker mounting plate does allow the device to sit further away from the windshield, providing room for the camera to tilt up. However, it appears that the camera doesn't till up far enough. When mounted this way, on level ground, the horizon is at the top of the screen (2% sky, 98% road). I noticed that the image corrects itself if I were to mount the DVR body horizontally but the lettering is now upside down. I haven't played with it enough to learn if the lettering orientation can be adjusted. I now need to build a small box to raise the camera high enough to see over the molding in order to mount the camera horizontally. Another option would be to build a small wedge to mount to the windshield that the camera would then mount to. I think that if the camera could rotate 2-3 more clicks toward the vertical position, it would be fine. As-is, I think the "vertical windshield, no problem" is a stretch. Color me excited, disappointed, and asking if there is something else that I'm missing for vertical windshield applications.
