Video Quality
Midri
Belgium
Goodday,
I've just bought a Mini 0806 from a local vendor. He states that it is a 5th batch (it came preinstalled with the latest drivers).
First of all the blue led doesn't turn on. It does charge and the camera starts when the power is on, so I thought I'd leave it there. But I've done a few test drives and when I look back at the recordings, it really isn't that clear in my opinion, at least not as clear as the recordings I've seen online.
I have the CPL filter mounted on (turned it to get the most clear image possible) and have it set at 2560 * 1080 on Super Fine. It seems quite blurry compared to other Mini 0806 videos. I've uploaded a 3 min test footage I've made (first part without mic, then half a minute turned on to test that one as well):
This is my first dashcam so I don't really have any experience with how it is supposed to be. Am I just a bit too demanding or?
Looks OK to me except I think there is a lack of contrast like there is some sort of reflection across the image, try recording some footage with the camera outside the car to see if it is better without the window in the way. If it is then maybe have another go at adjusting the CPL, you should set it to reduce reflections, not to give the clearest image - point it at your TV, it should block out the TV image completely when the camera is rotated to 90 degrees from normal...
Also, try upgrading your firmware to: https://dashcamtalk.com/forum/threads/0806firmware-150323-dct-custom-bitrate-version.11232/
Goodday,
That's strange. I have one that also has a defective blue LED, but I'm in the US.
@Nigel: I've played a bit more with the CPL filter, tried your suggestion with blackening out the TV and ofcourse the little marker on the CPL filter is a bit off. I've put another marker on myself. I've also installed your firmware on the cam. Thanks for the tip and the firmware!
Too bad I couldn't try the dashcam in the same conditions anymore since night has fallen, but I'll try it later.
I do however just got to work and tried the dashcam in night time conditions. I'm really pleased with the result:
@RavenManiac: I bought it from a Dutch vendor. I've googled a bit but haven't found that many cases of a defective blue LED. If it's just the blue LED that's defective, I'm going to keep it.
Now I just need to figure out how to hardwire it to the car. Fusebox isn't a problem but can't seem to find a ground point. I'll have a better look later this week.
You want to turn the subtitles off on your viewer to get rid of that big text at the bottom, or use another viewer.
The lights should be clean circles, the star effect and halos suggests your window glass is not clean, that may be spoiling the image in the daylight too. Or maybe you have cleaned the window with something that leaves a residue behind - try some simple kitchen washing up liquid. Check the lens too but I think that is on the window.
For a ground point, normally any metal screw will do, best to use an official one if you can find it though.
It does seem a bit bright and washed out. Maybe it's worth tweaking the exposure compensation.
A bit worrying that no number plates are very clear. But your country's plates are different to mine. The custom bitrate firmware should improve things.
Try angling the camera down so less sky is in view. I think that might be causing problems.
It's really hard to tell since YouTube trashes the quality of most videos. You may want to try uploading the raw video to DropBox or some other cloud-based file server so we can take a look.
I prefer a .png file like in the dark image above, it's a lot smaller and easier to access!
In my experience EV is best left on zero for the 0806. I suspect it looked "a bit washed out" in real life too? It will look better on a sunny day with clear air.
True, but the sharpness of the added text gives an idea of how potentially sharp the rest of the image can be.
FYI, any CPL filter is going to darken the image a bit.
this is on a sunny day with the sun above and some to the right. cpl filter is on but because the camera is mounted back of the windshield , its 'average' of light tends to make the outside brighter.
mine probably needs to be focused further out. something interesting is the sharpness doesnt change nearly as much as you might guess between stopped and traveling quite fast.
Hey PurpleMoon, it's been a while. I hope you are well.
Were you seriously going 121 mph? If so, do you have any footage of the state trooper trying to catch you? LOL
i have video but its unsafe for folks to speed and i dont encourage it. i'll get some at a track one day and that i will post. yea, 121+ 13sec and last part is going UP hill! lol anyway, i really figured the blur would be quite noticeable , it is on the extreeme sides but not so much toward the front.
View attachment 17005 View attachment 17006 this is on a sunny day with the sun above and some to the right. cpl filter is on but because the camera is mounted back of the windshield , its 'average' of light tends to make the outside brighter.
Nice job! Nice ride as well πŸ™‚
