DashCamKing
- Jan 24, 2019
- United Kingdom
That is certainly not normal. The building on right side of the image is sharp while objects on the left at the same distance from the camera are not. The center of the image is markedly worse. Assuming there is nothing on the lens or a problem with the windscreen then I suspect one, or more, of three things are causing this: 1) a defective lens, 2) the lens is misaligned in the mount or, 3) the mount itself is defective and/or misaligned.I've posted before about this and been told it's normal. Can anyone explain why the difference in image quality between the 2 marked areas in this picture? It doesn't appear normal to me.
Light level probably not, but it could make the issue more or less obvious....I wonder if the issue is variable depending on light level and temperature?...
Temperature maybe, but only because there is something wrong; at current UK temperatures there should be no temperature issues.I wonder if the issue is variable depending on light level and temperature?
