My A118c suddenly won't record anything. When powered on the screen stays on and the record light flashes but the time seems stuck. If I remove power it appears to just slowly run down the remaining power and turns off instead of actually shutting down
I had the same problem before when swapping cards so I assume I have a bad SD card? Last time I had to format the microSD to "fix" it.
I see this guy had the exact same problem https://dashcamtalk.com/forum/threads/a118-stuck-on-not-recording-cant-turn-off.9138/
I am running: A118C.20160316
