Do I Need to convert 12V to 5V in order to work?
Will this also work then?Yes! The camera works on 5 volts. If you connect it directly to your car's 12V power supply you will fry the electronics in your camera.
The USB cigarette lighter charger that comes with your camera converts the car's 12 Volts to 5 Volts.
If you want to connect directly to you car's 12V system you will need the HK4 Viofo hardwire kit that is available for your camera. It too will convert the voltage to 5V.
https://viofo.com/accessories/254-7...29-prot130wm1.html#/38-fuse_type-not_included
why is that? Will connect to 12v cigarette lighter. It’s will only get powered when key is on ignition position 2.Yes, according to the technical data it would work. But you don't have a voltage monitor and there is a risk that you might have your vehicle battery empty.
No. Not directly to battery!I think you want to connect it directly to the battery!
If you want to use the cigarette socket, you won't have any problems if you use the included VIOFO charger/adapter. So what's your problem really?
If you don't want to connect directly to the battery (the HK4 kit would be ideal for that), then just use, as I already wrote, the VIOFO adapter and the VIOFO cable that you got when you bought the Viofo A119 mini 2.No. Not directly to battery!
I didn’t know that it can only powered by 5V, that why I asked here. Did not order with VIOFO HK!
