Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3κκκκκ Viofo A229κκκκκ Blueskysea B4K
You can just put both red and yellow into the same blue crimp connector on the one fuse tap - connect them together.The piggyback fuse tap has one wire holder at one end and the prongs at the other. (Will get it if I can on Thursday).
The Nextbase is on a 7.5 fuse, but is only a 2 wire kit if I remember rightly.. How many can be hardwired safely (to a second 7.5 fuse)?
Do I need 2 of these then, and connect one to the yellow cable into an ACC fuse, and the red cable into a constant fuse (and the black to ground of course)?
Alternatively you can connect the 3-wire hw kit up as per the instructions with 2 fuse taps, and then turn off parking mode in the setup.
