gse
- Oct 22, 2013
- Russian Federation
- Viofo A329S
@jokiin
does this mean we should understand wdr as hdr? then you need to fix the menu in the firmware so that there is no confusion and call it by your name.
Viofo is not using the HDR available on the sensor, only WDR - a single exposure with a Wide Dynamic Range, squashed into the range of the video file based on the menu setting. I think it is essentially a choice of gamma setting since it never has much effect on the highlights, only the shadows.@jokiin
the sensor only supports hdr, even if there are several modes, wdr has nothing to do with this, you need to call things by their proper names. It will be right.
It's not my product so it's not my place to dictate what it should be called@jokiin
HDR should be used for multiple exposure frames, WDR for single exposure frames from a sensor that can capture a greater range of light levels than you would normally use for video.It's not my product so it's not my place to dictate what it should be called
The IMX 335 can provide 12 bit image data, H264 stores 8 bit data, WDR is about how those 12 bits are mapped into the 8 bits, a high WDR setting would scale the full 12 bit range into the 8 bits, while a low or off setting would only use part of the 12 bit range resulting in overexposed highlights and black shadows, but a normal looking midrange instead of a very compressed midrange with little detail. This is a job for the firmware, not the sensor, the sensor just has to capture the image data.I understand this, but I do not understand how this is done if the matrix does not support vdr. done at the program level? How high is the dynamic range? have data?
data(s)hit no data on the use of wdr imx 335
