DonMartinos
Hello
I'm going to connect Viofo A129 Plus Duo using HK3 adapter to the fuse box in Dacia Logan III.
I found fuses i'll use, trailer (red) and lighter (yellow)
One of them is empty slot (trailer - marked red), can I connect to it fuse tap with only one fuse just for dashcam?
I am not an electrician, but looking at the diagram from this post ( https://dashcamtalk.com/forum/threads/which-side-of-a-fuse-is-hot-vs-cold.30136/post-353585 ), it seems to me that if I will connect it correctly (position A on diagram), it will work, and if I do it the other way, it will just not work.
