I tend to agree with bobcat here.Thank you for this post, you are confirming 99% of what I was guessing. It is showing a big difference compared to the first post of this thread and is based on a big experience with HK3, not with just one.
I don't know how is looking your listing and I am not asking to show me one to not be considered spam, but I think you need to find a way to tell them that the fuse must be verified on the fuse box of the car and not from any other source. Of course the order can be more complicated if the fusebox have both Normal (ATO) and Mini.
With the buyers which are reasonable you can explain that a Mini fuse tap can be used instead of Normal and instead of Mini Low Profile. More than that the Mini fits better compared to Mini Low Profile. So the only cases when Mini cannot be used are for Micro 2 and Micro 3 (which are very very rare).
PS: I am not interested in your store just because you are in USA and maybe Canada and I am from EU, so any buy from that region is too complicated for me, I prefer to buy from EU because of customs employers, taxes and VAT.
I have a story filled with frustration in regards to viofo hk3 hardware kit as well. 2 of them died on me already. I am waiting for a 3rd replacement. Email from the store confirms they have problems with these hk3 cables.
2 weeks ago I have purchased a129pro duo along with hk3 hardwire cable from a big reputable online store. The first cable worked on and off for 2 days, the second replacement died in 1 day.
After testing and installation everything worked flawlessly. I replaced the cable the same way and camera started working right away with no problems.
However, 24 hours later I have the same issue. The camera does not power up with HK3 cable at all again with a second cable.
The cable kit is connected to my 12v fuse box. This cable kit and the camera is protected with 10 amp fuse. Fuse is not blown and there is flow of power. I retested with multimeter that the cable gets proper ground, 12v constants battery power and 12v accessory power at the direct connections. HK3 cable receives verifiable power, but does not output anything.
This is what the store wrote back to me:
“So sorry to hear that you're having the same issues with your replacement hardwiring cable We have been seeing a higher number of inquiries regarding defective VIOFO hardwiring cables, and I think this could be our issue here (pretty bad case of bad luck). We have notified VIOFO of this issue, however, there's no way for us to tell which cables are affected and which are not.
I'll have another replacement shipped out to you. I recommend having this loosely run (IE. don't hide this within the vehicle yet) for you to monitor for at least a few days to ensure that this is fully functional. Just for transparency here, we've seen this effect about 10% of our customers who purchased a VIOFO dashcam within the last month or so.”
Any advice on what should I do? By the looks of it the next hk3 cable will die eventually as well?
