VIOFO Improvement Wishlist 2026
Is there a "Never" option now?
Hello,
Here are Screen Saver settings Tschingis is referencing, (see attached photo).
LCD Screen turn off after 1Sec, 3Sec, 15Sec, 30Sec, 1Min, 3Min.
There is no setting to have LCD Screen “Always On” because it may overheat the camera.
If you would like LCD Screen to illuminate after automatic shut-off, you can use Voice Command “TURN ON SCREEN” (see attached photo).
-Chuck
If I understood correctly, the user needs the screen to be turned off.
I’m not 100% sure either.
I think @HurlingFrootmig wants the LCD Screen to be “Always On” and never turn off.
I just wanted to explain how it currently functions.
Since the LCD Screen will only stay illuminated for 3 Minutes max, Voice Commands might come in handy.
Example: When someone tailgates him, he can say: “TURN ON SCREEN” to "deter” them.
For me, I would not rely on the LCD Screen to deter a tailgater.
Usually I slow down below the speed limit, engage my turn signal the “wrong way” and pretend I’m lost.
It doesn't take long for the tailgater to loose patience, and overtake me 🤣
I deploy a similar method when another motorist follows in my blindspot on multilane highways.
They will usually back off out of my blindspot, or they will pass.
I would like the remote control main button to be configurable like the two side buttons.
Correct. I'd appreciate an option in the screensaver dialogue that completely disables it, leaving the screen always on.
I can appreciate the argument about overheating, even though I haven't seen an official statement supporting that, yet. Yelling "Turn on screen" every 3 minutes can become a bit tedious, though. Especially on long winding roads where you're driving the limit and someone else can't pass, even if one were to pull the shenanigans you've described. Might just enrage them more.
Thank you for the clarification.
You are correct.
Don’t let me stop you from requesting a feature.
You may SUBMIT A TICKET to request this feature directly from VIOFO to get an official response.
A229 Plus. Allow 15 fps in time-lapse parking mode. Currently max is 10 fps.
This will probably never happen: Create a snap on / snap off wide-angle lens I can put over the front lens to use in parking mode. The front lens on the A229 Plus isn't all that wide.
The special firmware to keep wifi on: A229S_V1.5 260330 https://we.tl/t-56sgpy5GWHSi8zUG
?? Wishlist: I was asking about providing the A229 Plus with the option to do 15 fps in time-lapse.
I'll correct my own (too wishful) wishlist 🙂 The snap-on lens won't happen because the snap-on wide-angle will have to go over the regular front lens so too many layers of glass to go thru from an optics standpoint. GoPro has a Mod lens (fish-eye) but you have to take off the regular lens first and then put on the Mod lens.
A149 Pro dash cam has received support 1mA LPID , whereas the A329S missed out on this feature. @viofo @VIOFO Benelux @VIOFO-Support you have plan to add support 1mA LPID for A329S
Hello again,
Just in case VIOFO does not see this post, can you also SUBMIT A TICKET to request 1mA LPID for A329S?
To clarify @VIOFO Benelux is simply a retailer / reseller, (they do not make policy, or manufacture anything).
-Chuck
It may be possible, but I wouldn't hold my breath. As it appears that a lot of manufacturers that are advertising 5mA or 1mA low-power parking modes are utilising the latest Novatek chipsets, which the A329S does not have. Like they said, they will try. I think others like Vueroid with the similar chipset have achieved low-power parking modes, but I am unsure as to how much of that was contingent on the chipset itself.
