Update0921:
M4 - 3 in 1 Multi-Function Dash Cam system (DVR + Phone Holder + Phone Charger)
Update0905:
P6F - Full Body Waterproof Dual Lens Dash Cam
1) 2.0'' LCD screen with touch key
2) Front 1080P + rear 1080P lens
3) SONY IMX323 sensor; 6-layer all glass lens
4) Full boday waterproof
5) WiFi connection
M2F & M2F Pro
1) 3.0'' LCD screen with touch key
3) SONY IMX323 sensor; 6/7-layer all glass lens
4) Waterproof case for main body(M2F Pro)
5) WiFi connection
M6L
1) No screen design
2) Front 1080P + rear 720P lens
3) SONY IMX323 sensor + OV9712 sensor; 6-layer all glass lens
5) WiFi connection
VSYSTO 2CH camera system is designed especially for motorcycles. Aimed to simplify the use of cameras, for security, and pleasure. Compared to sports action camera, VSYSTO professional dash cameras are equipped with dual front & rear sync recording cameras, allows you to capture the unexpected accident evidence, and amazing travel scenery.
2) Manual Event Recording: Press the emergency button of wired remote to manually activate emergency recording mode.
Video files recorded in emergency mode are protected from being overwritten.
![61ZrO77-wSL._SL1001_.jpg 61ZrO77-wSL._SL1001_.jpg](https://dashcamtalk.com/forum/data/attachments/39/39861-b8312bcdf0bb2ce8f593aa4008e507ed.jpg?hash=uDErzfC7LO)
![61UWPSKiM8L._SL1001_.jpg 61UWPSKiM8L._SL1001_.jpg](https://dashcamtalk.com/forum/data/attachments/39/39862-7a0e6fe1c9e7875a22abc9706112ca0d.jpg?hash=eg5v4cnnh1)
![61o6Xa7HexL._SL1001_.jpg 61o6Xa7HexL._SL1001_.jpg](https://dashcamtalk.com/forum/data/attachments/39/39863-b7195d973ebc602974f4e5e3b20e2117.jpg?hash=txldlz68YC)
![61xdbaLNUoL._SL1000_.jpg 61xdbaLNUoL._SL1000_.jpg](https://dashcamtalk.com/forum/data/attachments/39/39864-58984d94c4f9cc17dc91a5abdb1f3db6.jpg?hash=WJhNlMT5zB)
![610W5g+0j5L._SL1001_.jpg 610W5g+0j5L._SL1001_.jpg](https://dashcamtalk.com/forum/data/attachments/39/39865-0c38266a9b9fdfb963d630e43caadf9c.jpg?hash=DDgmapuf37)
Front Cam Test
Rear Cam Test
![HTB141QWhCrqK1RjSZK9q6xyypXaI.jpg](/forum/proxy.php?image=http%3A%2F%2Fae01.alicdn.com%2Fkf%2FHTB141QWhCrqK1RjSZK9q6xyypXaI.jpg&hash=29db804574f9fff2d3b7a1def7cda5c8)
![HTB1XbqGXdzvK1RkSnfoq6zMwVXa2.jpg](/forum/proxy.php?image=http%3A%2F%2Fae01.alicdn.com%2Fkf%2FHTB1XbqGXdzvK1RkSnfoq6zMwVXa2.jpg&hash=52377acd49054adee3dd66bb2e28cdab)
Update0905:
5) WiFi connection
![HTB11GJyXEvrK1RjSszfq6xJNVXa1.jpg](/forum/proxy.php?image=http%3A%2F%2Fae01.alicdn.com%2Fkf%2FHTB11GJyXEvrK1RjSszfq6xJNVXa1.jpg&hash=0ff3db79ce0c8fd7c5d9b845151073db)
M2F & M2F Pro
5) WiFi connection
![HTB1rjVzXx2rK1RkSnhJq6ykdpXaQ.jpg](/forum/proxy.php?image=http%3A%2F%2Fae01.alicdn.com%2Fkf%2FHTB1rjVzXx2rK1RkSnhJq6ykdpXaQ.jpg&hash=9357aa26bf0a5b8529a52d6e179272d9)
M6L
1) No screen design
5) WiFi connection
![HTB1Xz4AXzzuK1RjSsppq6xz0XXa8.jpg](/forum/proxy.php?image=http%3A%2F%2Fae01.alicdn.com%2Fkf%2FHTB1Xz4AXzzuK1RjSsppq6xz0XXa8.jpg&hash=2bf31b7fe6fce3820d1eaaa8e12d0911)
- Especially Designed for Bikers: 2 channel separated cameras with each standard 2.5 meters extension cable for front and rear view recording. Good stability and friendly operation will let you enjoy the ride!
- Superb Image Quality: Both cameras are equipped with SONY IMX323 CMOS image sensor, 7-layer glass lens, 170° super wide angle fish eye lens. Brings a super sharp image quality, and crystal clear video.
- Metal housing: Designed with steel housing to disperse heat away from internal circuit.
- Built-in WiFi: Allows you to view (real time), snapshot, playback and download online wirelessly on your mobile device. APP supports both IOS & Android systems.
- Best Weatherproof Solution: IP68 waterproof cameras, and especially designed waterproof case. Allows you to use it under any weather condition.
- Super Capacitor Design: Without risk of battery explosion and with much longer life compared to lithium battery. Power through motorcycle’s battery never need to be charged. No need to worry about charging problem at all.
- Auto Power On/Off: Start automatically with your ignition, or any movement (ACC/smart power module) and turns off once the bike is not being used (keep recording about 3 minutes after your bike not being used for smart power module).
- GPS track (Optional): It will show your movement (with speed, coordinate, route) in Google Map of GPS player.
- Loop Recording: Support up to 128G TF card which you can record long time without overwritten. And it will keep continuously recording as 1/2/3/5 minutes (set on menu or APP) clips by overwriting the oldest files.
- Emergency Recording Mode
Front Cam Test
Rear Cam Test
