Maybe someone should measure it, just to check if their measurements are correct...
125 / 16 * 9 = 70, so why is the front only 62° vertical? An aspect ratio of 16:7.9 seems a bit odd, presumably it is stretched vertically when recorded in the 16:9 aspect ratio file?
According to the right angle triangle calculator on Google, H 125 + V 62 should give a diagonal of 139°, not 165°.
101 / 16 * 9 = 57, so why is the rear 60° vertical? At least the rear is fairly close to 16:9!
According to the right angle triangle calculator on Google, H 101 + V 60 should give a diagonal of 117°, not 139°. That seems quite a long way out.
