I know this one will give you a giggle as I know it'll be something so simple but I've got to ask because I don't have a clue. I'm pretty much an electrical dummy.
So i hardwired my dash cam which sort of worked ... because it would get power and record but it also sort of didn't as randomly i would turn the key and the dash cam display would be white and it'd not record, i'd have to take the power cord out and put back in. Or throughout the journey i'd see the "start recording" message on the display, meaning it was constantly getting and losing power. Or it would look like it's recording - as in the display would be illuminated, but if i plug the SD card in to the PC to check something, it would turn out an entire 30 minute journey didn't record.
From asking here it was concluded that it was the power supply. A bad hardwire kit. So I bought another from a different seller and we'll see if that works out or not.
Thinking ahead though, especially if it doesn't work out, the car audio guy that i bought the camera off and who did the original hardwiring in to my old car used the power supply (12v male) that came with the camera and had this plugged in to a 12v female that he had hardwired behind the glovebox. He actually wired it in to the cars stereo wiring. I'm not about to go doing that but I was thinking of tapping a 12v female in to another fuse and then wiring the original power supply cable in to the 12v female i just installed.
Problem is i don't actually know the terminology of what to search for. <insert giggles here>
I know i need one of these which i believe is a fuse tap
With the positive wire from the 12v female plugging in to the blue end in that image.
I need whatever is on the end of that red wire in the above image to attach it to the red wire on the end of the 12v female.
I also need to attach something to the end of the negative lead off the 12v female. Now many of these kits i see come with this crabs claw like end. I'm pretty sure the term isn't crabs claw but who knows
What i actually want is a ring as it's just much easier to thread a bolt through it somewhere behind the glovebox and voila job done, rather than finding your crabs claw doesn't quite grip the bolt as the bolt is a bit on the thick side.
I've seen videos where people are crimping these connections. I have no electrical crimp tool but I do have a computing crimp tool identical to https://www.amazon.co.uk/gp/B00QRVG15Y which I used when making network cables for throughout the house. I'm guessing they're going to be no good for this job but i'll ask all the same? If I need a different tool specific for electrical wiring then which crimp tool for the job as i see some looking all different to each other with a wide range of pricing. I don't want to pay £20 for something i'm going to use once when i can buy something that'll tick the box for £5.
Thanks.
![wAGudrz.jpg](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FwAGudrz.jpg&hash=8812eb1681b46db97c5eea106c6e21ea)
![71i9GNo.jpg](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F71i9GNo.jpg&hash=4789776b9a1413732a9c06f19e4f0ccf)
![G81UGs7.jpg](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FG81UGs7.jpg&hash=04b3aa2a4e3edd1ab1b96a7858b70c8f)
![Big grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Thanks.
