Where did you mount your 12v accessory socket when semi-hardwiring?
Damn Dirty Ape
Illinois
I'm prepared to use my add-a-circuit and a 12v accessory socket to semi-hardwire my SG996 that should be coming on Saturday. I plan to use the 12v plug it will come with and install this port. I've looked for some areas but wanted to ask where you might have mounted yours? It's not going to be easy to get to no matter what - it's a 14 Infiniti Q50 with not much room under the dash. I can run some wire for both the ground and 12v if I need to, but there is nowhere that it will mount and be visible, thus the hide part.
After a few months I will be using a hardwire kitbut for now this is what I want/need to do.
I hid the socket under the dash with the plug and ran the wires behind trim around the windshield. That's my permanent hardwired install.
