country_hick
- Dec 10, 2014
Is there any reason to use the mobius charging cable instead of a standard usb cable with the correct end in your car?
Pins. A standard 5 pin data cable will put the Mobius into standby, while a charging cable with the data pins shorted will allow for power on record.Is there any reason to use the mobius charging cable instead of a standard usb cable with the correct end in your car?
What do you mean by "mobius charging cable"? The cables that comes with the camera are standard USB cables with standard-A and mini-B plugs.
