Will Not overwrite when full
Ryan Drean
B40 A118
This has to be a simple solution. But my issue is basically that. It filled up the disc and then it acts as if it is recording when I drive but it hasn't recorded a new file in months. Not since it filled it up from the first day I started using it.
I had not needed to check my files until now. So Basically I bought it in August. After a couple weeks or so I looked and it had been filling it up nicely, great recordings, so I just forgot about it. I glance over to make sure its running when driving from time to time. BUT today I noticed the last recording was about the Beg of Sept. OR about 32 GB worth of recordings from the original start date.
I don't see a menu setting to tell it to overwrite. I do see looping which I have set to 5 min, but that's unrelated. Any help? Appreciate it!
Looks like your loop recording is off.
Set loop recording on 3 or 5 minutes.
Also check if the files are protected, if they are, you have to format the card regularly and increase G-sensor so it doesn't protect when you go over bumps.
OK...loop rec was def ON, set to 5 MIN. Ill try 3 MIN. just to see if that impacts it for some reason.
I was told to turn G-sensor off by someone else. You disagree? I had mine set to the highest sensitivity.
Do you know what format I should make the card? Its Fat32 now. Thats the way it came and I didnt reformat. Perhaps exfat? Its also NOT protected it IS read/writable
Whether it will help your looping problem or not I don't know but it is always a good idea to use the camera to format the SD card you intend to use in it. Do this periodically.
OK great, Ill do that too now. Won't hurt. Thanks
Highest sensitivity may be the opposite of what you think.
It may be too sensitive.
Just turn it off and check SD card every few weeks.
there was actually a bug in the older firmware - i had this issue too. if the g sensor is set to anything besides off, it will claim card full and not record anything. you can upgrade the firmware or just turn off g sensor. turn off motion detect too if its on since it doesnt work right on this cam anyway.
G-Sensor is the work of the devil!
Only kidding but living in a rural area, often driving on bumpy dirt and gravel roads I usually turn G-Sensor off or keep at the lowest setting. Depends on the particular camera.
OK, thanks everyone for the tips. I wouldnt have guessed G-sensor would be the culprit. I've killed it and shall pull it out in 2 weeks.
I missed some EPIC Texas weather though!! Literally whole tree flying by in front of me. So much water it was like driving in the bottom of a lake. It was the first time in Months I wanted to grab the footage! Oh well, next time
I encounter so much stuff I pull my card at least once a month, which also helps make sure it's actually recording and that the card hasn't gone bad.
Had some pretty nasty weather here last few days too, especially this morning. Neighbor lost part of a tree, and some stuff I just planted a few days ago got uprooted and had to be replanted.
Oh, after changing settings, did you format the card in the camera just to have fresh start/clean slate?
use G-Sensor at low or Off setting only, having it on high will fill the card with write protected files, format the card before you start again
if you use a Mac and you've been copying any files off with the Mac format the card in the camera afterward
So if I use a card reader to read the files on a mac, I should format it afterward? What if I have it set to be write protected (the little switch thingy on the adapter)? What does the mac do that makes it not work? I've always done this (read files on a mac using a card reader), wonder if that is something to do with my recent problem, and the file being write-protected was just a red herring...
reading the files is no issue, if you cut and paste, or just delete files with a Mac they leave some hidden files behind that the camera can trip up on, rather than explain that nuances that go with that it's easier just to advise to format afterward, if you had write protected the reader I'm not sure how that could have been your issue, if you had moved a file from one directory to another I'm not sure how you could do that when write protected though, had you done that then yes the Mac would have left a system file that the camera would have a problem with
The question about turning on write only was for "future reference", no I have not done that in the past. Was just asking if that would be a solution for the future so I wouldn't have to format the drive every time I plug it into a mac. I'll check the card for system files next time I go to the car.
So I'm guessing it is the .DS_Store or similar system files tripping up the unit? That is good to know, thanks for giving the details! I like knowing "why" behind things, it helps to self-troubleshoot problems, and helps to remember something if I know why it is that way. Plus I'm just a curious person.
I wonder, does it cause a problem when you plug into windows if it adds Thumbs.db file?
I'm not sure if any Windows issues, never heard of it causing a problem, Android will add some files and that doesn't seem to cause any grief, just seems to be a Mac thing from what I have seen
android and windows don't add "dotted hidden" files like ".macos" and such. maybe that's the issue - files with no "filename" because they start with a dot (as opposed to "filename.ext"). i've not had any issues with windows adding the sysvol folder, nor android's "android" and "data" folders. they're hidden, but that's just an attribute, not relying on the old-fashioned dot-filename to "hide" them. android knows how to handle those since that's something carried over from the older unix systems it's based on, as does macos and for the same reason, but most software doesn't really use that anymore since it's kind of but not really deprecated.
Wow you are not joking, Macs like to add files like crazy! First, just sticking it in the computer, it added these:
Code:
zumba532:JON CAR jonathanfoote$ ls -la
total 384
drwxrwxrwx@ 1 jonathanfoote  998989866  32768 Apr 30 09:07 .
drwxrwxrwt@ 5 root           admin        170 Apr 30 09:07 ..
drwxrwxrwx  1 jonathanfoote  998989866  32768 Apr 30 09:07 .Spotlight-V100
drwxrwxrwx@ 1 jonathanfoote  998989866  32768 Apr 30 09:07 .Trashes
-rwxrwxrwx  1 jonathanfoote  998989866   4096 Apr 30 09:07 ._.Trashes
drwxrwxrwx  1 jonathanfoote  998989866  32768 Apr 30 09:07 .fseventsd
drwxrwxrwx  1 jonathanfoote  998989866  32768 Feb 26 18:38 CARDV
Well, when I first stuck it in, those files were a lot older, like from Feb. So I deleted it, removed the card, stuck it back in and they were back! So it adds them just sticking the card in. Though I don't think those mess with the camera since like I said, the date originally was Feb and the loop feature has been working ok since then.
Then when I watch a video, it adds a small ._2015.... file (basically the file name with ._ in front) in the folder itself! Guessing that might trip it up. So I removed those, then un-mounted the card. Stuck it back in with the "read only" switch flipped, and checked just to make sure no extra files were added "on exit". All looks clean now, but man OSX really likes to add system files sheesh!
I'll be using the read only switch on the micro sd card adapter from now on whenever I stick the card in my mac to watch anything. Again thanks for the info! 🙂
