Thank you so much for your quick answer. The hardwire kit for Vantop-H612t mirror dashcam are only ccc+ with black one for the car body. But the 70mai hardwire kit are three!!! CCC+, ACC and earth wire. Can you show me a Screenshot on how to do this? I will be so much appreciative. DankeschönWillkommen an der forum Femi. ( please forgive my meager German skills, it was something i learned myself 45 years ago )
I have run several systems on the same piggy back fure adapters, CUZ i dont like to look for more unused fuses for this, it have worked fine with a 5 A fuse for the new Circuit.
So like this i have run a dual channel system and a 3 channel system on the same 3 wires.
Of course i used the hard wire kit for each camera system so had 2 of those, one street guardian and the other viofo, but on the 12 V side the shared the same fuses.
Even if your one system have a 3 wire hard wire kit and the other a 2 wire, you should be able to share the same fuses in the fuse box.
In my case as i recall it is a 10 or 15 A fuses i am tapped into the the piggyback fuse adapters.
Thank you so much for your quick answer. Should run a complete hardwire kit connection? The hardwire kit for Vantop-H612t mirror dashcam are only ccc+ with black one for the earth. But the 70mai hardwire kit are three!!! CCC+, ACC and earth wire. Can you show me a Screenshot on how to do this with piggyback fuse? I will be so much appreciative. Dankeschön
Ich bedanke mich sehr von Ihnen.
Sorry I meant VCC+
This is old schooI. I still use them though. But WAGO cable connector are very good too.As i test cameras and often change instead of the crimp connectors on the fuse adapters i use electricians screw terminals.
Also my fuse box are in a bad place, at least when you are no longer young and flexible, so i made it more easy for myself.
Old stuff but very reliable I thank you so much for your assistance. I'm now waiting for my 70mai x200 Dashcam to be delivered. I will surely inform you about the result. I wish you a blessed day and happy Christmas in advance.Indeed, it was not connectors like that i used pretending to be a electrician in my nieces house, they have since then had parts of the house rewired and thank god for that, it was very old stuff and i also advised they had a professional take a look at it.
But as i had some of those lying around and its just 12 Volts i am fine using them.
Thank you once again. I'm just wondering because Nextbase wrote "don't remove the 2A"2 A are fine for 1 system, but if you are going to put 2 systems on those 2 fuse adapters i would change to a 5A fuse, that have worked fine for me.
Really a dashcam do not use 2 A when in operation, more like 1 A or a bit less, but i think they can spike a little higher during boot.
I think you can try the 2 A fuses, if the are oveloaded they will just blow, just keep that in mind if your 2 systems suddenly turn off.
I will surely try this after Xmas. Ive been running Vantop-H612t mirror Dashcam with this (2A, 10A is from System) Nextbase Hardwire kit. Smooth runnings. It's a new experience for me with combining two cams cables together. I wish you a joyful Xmas. Thanks.I think they pre installed the fuse as otherwise people might not get which one of the 2 slots are for the new circuit fuse and what slot are for the fuse in the fuse box you will be tapping into.
I dont think they have permanent installed the fuse,,,,, that would be silly IMO
Thank you so much. Everything worked fine. I even used 10A to 10A for ACC. And 15A to15A for CCC+. I used WAGO connection too. I thank you so much.I will surely try this after Xmas. Ive been running Vantop-H612t mirror Dashcam with this (2A, 10A is from System) Nextbase Hardwire kit. Smooth runnings. It's a new experience for me with combining two cams cables together. I wish you a joyful Xmas. Thanks.
Ja WunderbarWunderbar
