I've had the device since March '15. It was professionally installed, with voltage regulator (power control is off, should I set to 11.8v? MotoPark set Dim 1 Down, 2/3/4/5 Up).
It has two SanDisk ultra 128g cards. For a while, even with the cards installed I got an error to insert the cards. I purchased two new SanDisk Ultra 128g and the problem seems to have gone away.
I am using the 1.01.09 firmware per the recent posts. I formatted the cards in the device. Now the device is producing the following problems:
No Touch LCD:
LCD doesn't light up when touched. I have the device set to turn to black after 30sec. However, the only time it turns on is when I unplug and replug it. Set to Standby 30sec. Led off.
Low FPS:
The device is producing an image on the screen every 2 seconds or so. It's an utter slide show. I haven't confirmed this problem is producing the recorded video like this. Set to 1080P30/low/low front and rear.
These problems aren't consistent. It's on and off. As I type this, like bringing your car to the mechanic or dog to the vet, it's working properly. Very frustrating. I drive 40,000 miles a year and need some type of reliable protection against idiots on the road. I just want to feel comfortable it's working without constantly checking it, unplugging and replugging.
Any help? Happy Holidays!
No Touch LCD:
Low FPS:
