Yeecore 4K Video Recorder Issues
Curt
Post Falls, Idaho
After recording sessions from my vehicle, I take the mini memory card and install it into a USB adapter to view the recordings. The recordings do not show up, they will play but with a blank view. What must I do to be able to see each recorded session?
Welcome to the forum Curt.
It could be a missing codec, you could try the VLC player which i think come with codecs.
Also be careful playing files from little provided USB card reader, these are often very slow card readers so lags can occur, but if you copy to PC first you should be good.
Hello, did you solved this issue when you change other player?
If not, please try replacing the SD card, We recommend SamSung high speed U3 SD card , not recommend SanDisk or any other not famous brand SD card. Any questions, better contact the Yeecore support.
