The A329T is an update to the VIOFO’s flagship dash cam the A329. The camera is very similar to the A329 but includes a 3rd camera. While most 3-channel cameras cover the front, rear and interior of a vehicle, the A329T is unique in adding a telephoto camera.
The VIOFO A329T is based on a Novatek NT98530 processor. It uses a 4K Sony STARVIS 2 IMX678 CMOS sensor for the front camera, a 2K Sony STARVIS 2 IMX675 CMOS sensor for the rear camera and the same IMX675 sensor for the telephoto camera.
Note that when the A329T was released, VIOFO also released 3 similar dash cams:
- A329S (3-channel: front, rear and interior)
- A329SW (3-channel: front, waterproof rear and interior)
- A329WW (3-channel: front and 2 waterproof rears)
While the 4 camera models are similar, this review will focus on the A329T
Telephoto Camera
Unlike most dash cams with only 1 front facing camera, the A329T has 2 front facing cameras. The main camera has a traditional wide angle lens at 140° while the telephoto camera has 4x optical zoom and a 35° angle lens. This telephoto lens does an excellent job of capturing license plates in various lighting conditions. Many dash cams do not capture legible license plates in low light conditions.
Dashcamtalk members have been experimenting with telephoto lenses since 2017 and it is great to see manufacturers starting to roll out more cameras with this feature. One of our members, Julian23 has shared some night snapshots from the Autobahn at over 270KM/H and vehicle license plates are visible.
The VIOFO A329T has excellent video quality, similar to the original A329. The front camera records 2160p (4K) video at 60fps with an average bitrate of 65 Mbps. This high bit rate delivers excellent video quality during the day for the front camera and good performance at night.
The rear camera records 1440p (Quad HD) video at 30fps with an average bitrate of 27 Mbps. While not in par with the front camera, the rear camera does a very good job during the day and an average job at night. That being said it is one of the better rear cams we have seen on a multi-channel dash cam.
The telephoto camera records 1440p (Quad HD) video at 30fps with an average bitrate of 27 Mbps, the same as the rear camera. Overall this camera provides very good images day and night to capture license plates. The combination of the wide angle front camera and narrow angle telephoto camera makes the A329T one of the best for capturing license plates.
The VIOFO A329T has a 2.4″ screen, g-sensor and a GPS mount. The camera comes with WiFi 6, 5GHz & 2.4GHz. This is the first dash cam we have seem that utilizes WiFi 6, and it significantly speeds up the downloading of clips from the dash cam to your smartphone with either the Android or iOS app.
The A329T uses the familiar wedge shaped design as many of the other VIOFO cameras and comes with an adhesive mount. The camera cannot swivel to record interactions at the driver or passenger windows. Build quality is very good, and the camera comes with audio and screen error notifications.
This is a medium sized dash cam at 99 x 61 x 43mm. Not the smallest camera but not overly large either. The rear camera and telephoto cameras are both 71 x 38 x 28mm.
The A329T supports the following parking modes:
- Auto event detection or buffered parking mode
- Time-lapse parking mode
- Low bitrate parking mode
- Low power impact detection (turns on 1-2 seconds after impact)
- Hybrid parking recording (combines 2 parking modes above)
To enable these parking modes, you will need to hardwire the dash cam to your car (the VIOFO 3-wire hardwire kit has a low voltage cutoff and is recommended). VIOFO has also a geo-fencing feature where for specified areas, like your garage, the camera will shut down instead of going into parking mode.
The A329T supports voice commands in 4 languages (English, Chinese, Russian, Japanese). The Lock Video one is the most useful, the rest are unlikely to be used on a regular basis.
The VIOFO A329T also supports external Solid State Drives (SSD) up to 4TB. The dash cam comes with a USB-C cable that can connect to an external SSD drive which can be hidden in the vehicle such as in the glove box. Some users have had issues with SSD drives so ensure you choose a recommended one from VIOFO.
The A329T can record to MicroSD cards as well like most other dash cams. However, the camera will not record to both at the same time. You will need to choose whether to record on the SSD or MicroSD card.
VIOFO is responsive to questions and have good support. They also provide regular firmware updates and take into consideration user feedback. VIOFO also provides a 24 month warranty (18 months plus an additional 6 months if you register online) which is better than most dash cams.
Some users have had issues with SSD drives with the A329T. If you plan to use an SSD drive, ensure you utilize a recommended model from VIOFO.
Sample Video
A number of our members have created detailed reviews of the A329T: Augustus, Julian23, EricSan and Dan-UK1415.
Another feature that VIOFO offer is multiplex videos, allowing videos from 2 or all 3 channels to be combined into 1.
The VIOFO A329T has very impressive video quality for all 3 channels with STARVIS 2 sensors on all cameras. Where the A329T really shines is license plate recording. This is likely the best camera for that purpose. The A329T also delivers some unique features such as 4K 60fps front camera recording, external SSD support, low power impact detection, multiplex video and WiFi 6.
Build quality of the camera is very good, a 24 month warranty with registration is provided and VIOFO provides firmware updates to improve the camera over time.
The primary negative is the high cost at over $450. Having separate cameras for the front lens and telephoto lens may not be ideal for some purchasers. Overall this is one of the best cameras to consider if great video quality and license plate capture are your top priorities.
See what other owners say about the A329T on our forum.
You can download the English User Manual here.
Data Sheet No specs match that search. Hardware Layout Scores Latest Prices Prices updated November 5, 2026 Listings may be sold as different kits, including front-only, multi-channel bundles, hardwire kits, or accessories. Check what is included before buying. We earn a small commission from links on this page which helps support the site. Read our affiliate disclosure for more details.Technical Specs
Spec VIOFO A329T Brand VIOFO Model A329T Channels 3 Channel Setup Front, Rear, Telephoto Form Factor Wedge Release Date Jun 2025 Country China Warranty 24 months with registration Spec VIOFO A329T Processor Novatek NT98530 Video Format MP4 Compression H.264 Screen Size 2.4" Touchscreen No Mount Adhesive Power Supply 5V Battery Type Capacitor Spec VIOFO A329T Parking Mode Buffered Wi-Fi WiFi 6 GPS Yes Apps Android, iOS, Windows, macOS Cloud Connectivity No Voice Commands Yes Spec VIOFO A329T SD Card Type MicroSD, SSD Max Card Size 512GB Operating Temperature -20°C to 65°C Swivel No Error Notification Audio, Screen Camera Units
CMOS Sony STARVIS 2 IMX678 Max Resolution 3840 x 2160p (4K) FPS 60 Bitrate 65.0 Mbps Viewing Angle 140° Dimensions 99 x 61 x 43 HDR Yes – scheduled CMOS Sony STARVIS 2 IMX675 Max Resolution 2560 x 1440p (2K) FPS 30 Bitrate 27.0 Mbps Viewing Angle 160° Dimensions 71 x 41 x 30 HDR Yes – scheduled Ratings
Where to Buy
Published: December 18, 2025
