start a conversation is a PM
Do you think, cpl filter can improve video quality? Hope to hear your opinion.hi all
this afternoon I finished making & installing a CPL on my P II.
This is the video I took shortly afterwards.
There are still some reflections. BUT the colour is way better, with red looking red & green look green. So I'm happy
here the finished item, installed with filter fitted
And without filter
It's permanently fixed in place with 3M Outdoor double sided tape. The downside of this is that the tape is grey, rather than the preferred submarine black.
The base
is a submarine black plastic plumbing/electrical piece. Whilst the outside was of a good size, I had to excavate the inside to make it clear the OEM lens housing.
To which I added a more or less standard filter 37 - 49mm filter adapter
before, with the screw mount still present
After, ready to glue to the plastic piece.
Finished & installed
taken without a without CPL filter
taken without a with a CPL filter
from the front
The adapter makes it very easy & cheap to remove & replace the CPL.
I may install a lens shade, if I can find a suitable version.
david
hi all
And without filter
The base
from the front
david
Good afternoon. After the test assembly with a CPL filter can confidently prove that the video quality in the daytime is much better than without the filter. And at night better without CPL filter.Do you think, cpl filter can improve video quality? Hope to hear your opinion.
Best regards,
Thanks for the reply. I saw the raw data from you upload file. It is quite different.Good afternoon. After the test assembly with a CPL filter can confidently prove that the video quality in the daytime is much better than without the filter. And at night better without CPL filter.
You are expert, better than me,,,Good afternoon. Video review of how to make a CPL filter for Panorama 2 own hands.
Thank you. Yours!You are expert, better than me,,,
yes, this will work, I have the same
A | panorama lens cap and case | II / S | 4 | |
What CPL lens do you use for Panaroma II S | II / S | 9 | ||
B | Cleaning the lens | II / S | 3 | |
Panorama II Lens Housing size / measurements for CPL Filter Step-down adapter | II / S | 5 | ||
Lens Cap for Panorama II | II / S | 13 |
