My english is not good but tried some stringd.
Type of wav file:
wav audio file
Sampling rate : 8 000 Hz
Bit depth : 16 bits
Overall bit rate : 129 Kbps
This is the text:
Attention! Mode is enabled debugging emergency.wav << Attention! Debugging mode is enabled .
Checksum is wrong boot loader boot-sue-fail.wav << Boot loader checksum is wrong .
Checksum is wrong the root filesystem fs-sue-fail.wav << Root file system checksum is wrong .
Checksum is wrong kernel kernel-sue-fail.wav << Kernel checksum is wrong .
Checksum is wrong application software pt-sue-fail.wav << Application software checksum is wrong .
Video recorder turns off exception_power_off.wav << The video recording will stop .
No file checksum boot loader no-boot-sue.wav << The boot loader file has no checksum .
No file checksum the root filesystem no-fs-sue.wav << The root file system has no checksum .
No file checksum kernel no-kernel-sue.wav << The kernel file has no checksum .
No file checksum application software no-pt-sue.wav << The application software file has no checksum .
Please do not turn off video recorder during upgrade no-remove-power.wav << Please do not turn off the camera during upgrade .
Begins overload video recorder reboot.wav << The camera will restart .
Check memory card sdcard_check.wav << Please check the SD Memory Card .[/b]
Update the video recorder, please not turn off power system_upgrade.wav << Firmware upgrading. Please do Not! turn off power .
Boot loader updated successfully upgrade-boot-ok.wav << Boot loader updated successfully .
Begins upgrade boot loader upgrade-boot-start.wav << Boot loader upgrade will begin .
Video recorder upgrade completed successfully upgrade-complete-ok.wav << The firmware upgrading completed successfully .
error one when you upgrade video recorder upgrade-err1.wav << Error One occured when you upgraded the camera .
error two when you upgrade video recorder upgrade-err2.wav << Error Two occured when you upgraded the camera .
error three when you upgrade video recorder upgrade-err3.wav << Error Three occured when you upgraded the camera .
Kernel updated successfully upgrade-kernel-ok.wav << Kernel upgrade updated successfully .
Begins upgrade kernel upgrade-kernel-start.wav << Kernel upgrade started .
Not found bootloader upgrade-no-boot.wav << Boo tloader upgrade not found .
Not found kernel upgrade-no-kernel.wav << Kernel upgrade not found .
Not found application software upgrade-no-pt.wav << Application software upgrade not found .
Not found root filesystem upgrade-no-rootfs.wav << Root file system upgrade not found .
Application software updated successfully upgrade-pt-ok.wav << Application software updated successfully .
Root filesystem updated successfully upgrade-rootfs-ok.wav << Root file system updated successfully .
Begins root filesystem upgrade-rootfs-start.wav << Root file system begins .
Begins application software upgrade-pt-start.wav << Application software system begins .
Begins firmware upgrade video recorder upgrade-start.wav << Firmware upgrade system begins .
Attention, updates without checksum files upgrade-wo-sue-start.wav Attention! File without checksum used for updating .
Update completed successfully upgrade_complete.wav << Update completed successfully .
Unknown error occurred when you upgrade software upgrade_fail.wav << Unknown error occurred when trying the software upgrade
Versions are different version_miss.wav << The versions are different
Reboot the system_reboot.wav << Reboot the system
After the << I put some examples of translation.
enjoy,
Mtz
