Good News:
I finally got around to running/hiding the power wires to both front and rear dashcams. (Everything all tucked away, neat and tidy!)
The DIY experiment of wiring things to my interior lights always on feed was a success as well! This means my recordings start as soon as I unlock my car with the remote. See the following link for more details.
http://dashcamtalk.com/forum/threads/wire-dashcam-interior-lights-live-feed-longer-recordings.2363/
Bad News:
I was trying to re-locate and test place my mini 0801 in the perfect rear window location to minimize window heat strip lines using only a partial temp stick. I accidentally let it fall off the window and drop to the carpet below. (only 1 foot or so) Since the DashCam was attached to the GPS base at impact, I think it caused enough pressure to crack open the horseshoe support leg. (see photo)
It didn't fall very far, but it still did a number on my base. The DashCam no longer stays in the base. Luckily I have another base from my second 0801 I can use for now. I'll have to order a replacement either way so my spare 0801 is whole. (letting a contractor friend using it in his truck in the near future) I'm contacting Givoe for new GPS mount. ($11)
So FYI! Be careful, the plastic is not forgiving at all. I guess I could try gluing it but you know how that usually turns out.
