Swinder
- Oct 31, 2017
- United Kingdom
Hi all.
Purchased my SG9665GC V3 just over a week ago through Amazon.
Initially all was fine but over the last 3-4 days it keeps coming up prompting to erase all data. If I confirm it will start recording once done, if I opt to leave the data intact it won't record and won't even go into the menu.
I have done a full format using the SD Card Formatter tool mention in other threads, initially it worked and everything was fine. After a day or so it started to play up again.
Is there an option I have stupidly enabled or do I need to power down the unit in a certain way before switching off the engine to prevent corruption?
Unit is powered via 12v port if that is relevant.
