mr_milo
- Jul 29, 2014
- Mini 0803 (Front) Mobius (Rear)
So I got impatient... No response from local distributor still about getting a replacement
So I opened it up and found the LiPO has swollen, going to get a replacement that myself as it could be the cause of my issues
Also discovered where the version number & manufacturing date is hidden
Seems like mine is version 3, dated 5/11/2014
Serious considering, cutting a small hole in the 0806 body and mounting a JST female plug on it, so I can externally mount and connect a RC Plane 1 cell LiPO battery to the mini, eliminating the need to dismantle every time the LiPo fails.
Possibly even externally mounting this LiPO @ 2200mAh
http://www.hobbyking.com/hobbyking/store/__18558__Turnigy_2200mAh_1S_20C_Lipoly_Single_Cell_.html
This is a common problem with lithium batteries and heat. On my 0803 I finally gave up can modified it for capacitors. If you are already thinking about an external battery you might consider external capacitors instead. I haven't needed to change them yet. π
