deepocean1358
Could someone tell me what cable length I need to connect 2 Viofo A119 mini 2 dash cams in a BMW 3 G20 series. I am assuming the battery is located in the back.
I am looking to buy these cables, are these long enough? And do I need to order any additional gear?
viofo.com
viofo.com
![viofo.com](/forum/proxy.php?image=https%3A%2F%2Fviofo.com%2F2954-large_default%2Fviofo-hk4-hardwire-kit-with-type-c-usb-port-for-a119minia229t130wm1-dash-camera.jpg&hash=4c7a6ee9c012b36cd0055f917a4a8799&return_error=1)
VIOFO HK4 Hardwire Kit with Type-C USB Port For A119MINI/A229/T130/WM1 Dash Camera
HK4 Hardwire Kit is Type-C USB Port For A119 MINI/A229/T130/WM1 Dash Camera. Note: Fuse Tap is not included, check with your local car service shop or measure the size to confirm the type to use. If still unsure, consider this Full Set Fuse Tap with ATO, Mini, Micro2, Mini Low Profile Adapter...
![viofo.com](/forum/proxy.php?image=https%3A%2F%2Fviofo.com%2F1717-large_default%2Fviofo-4pcs2-packs-circuit-fuse-tap-with-ato-mini-micro2-mini-low-profile-adapter-holder.jpg&hash=323b59e43cd6e0f98aa6cfdff620be65&return_error=1)
VIOFO 4PCS*2 Packs Circuit Fuse Tap with ATO, Mini, Micro2, Mini Low Profile Adapter Holder
【Package】2pcs ATO fuse, 2pcs Mini fuse, 2pcs MICRO2 fuse, 2pcs Mini Low Profile fuse. 【Dual-Slot Fuse Holder】Provides one fuse holder to protect the original circuit and provides a lead with the second fuse holder for a new circuit. 【Compatibility】Used for hardwiring or dash cams, adding LED...
