deepocean1358
Which would be the most common / best in that case?The car has so many fuses/slots for electronics; I doubt it matters which size you choose, since you will have at least 2 of each size that you can use for the HW-Kit.
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
BMW 320d 2020 G20.What engine and gearbox have you got in the car?
I have downloaded my official fusebox schematics from the BMW website. Does this give certainty?
Are you are saying it is not possible to connect 2 independent dash cams front and rear?Your file also confirms what @Mtrev said.
F207 and F35 are free and can be used for the dashcam installation, but one is at the front and one is at the back of the car.
The hardwire kit requires 2 slots at one place (permanent + and ignition +).
No, it's just that in the diagram for connecting a BMW CarEye dashcam it is indicated so.Are you are saying it is not possible to connect 2 independent dash cams front and rear?
I need to figure this info out before I can purchase the cables correct? I wish they had used the same connection type for all of the fuses. There should be a universal "USB C" type of standard for these things :-DNo, it's just that in the diagram for connecting a BMW CarEye dashcam it is indicated so.
We can find the fuses that protect the Bat+ and ACC circuits. But online it is somewhat more difficult.![]()
That is more efficient, will order everything today.Since the fuse size is what hinders you from making the purchase, I'd advise you to just order a set with all fuse sizes. That way you can use the ones that you need (small & big).
The set only costs 5€ more than having only a specific fuse size.
Here's the link to the set: https://www.viofo.nl/de/products/set-van-4-zekeringen-voor-viofo-hardwire-kit
And the 119 Mini 2: https://www.viofo.nl/de/products/viofo-a119-mini-2?variant=46787712876873
Yes, Solomon's decision.Since the fuse size is what hinders you from making the purchase, I'd advise you to just order a set with all fuse sizes. That way you can use the ones that you need (small & big).
