hi there, first post and hope someone can help.
I'm trying to install DDPai M6 Plus on my 2015 grand Picasso with "Add a Fuse".
I just can't find a fuse inside the cabin that will work. All fuses are small and my piggy back fuse is the bigger size.
I finally found a fuse I can use in the engine bay but can't work out how to run the wire from the cabin to the engine bay.
Has anyone found a fuse inside the cabin that they are using which will switch off when ignition is off? Or an easy way to run the cable in the cabin without taking apart the whole car?
Thanks in advance
Irf
Thanks in advance
Irf
