You won't believe this; but when I loaded the supposedly 128 GB card into my card reader, the on-screen icon (on my computer) logged it as 124 GB! (I somehow lost 4GB along the way somewhere ...!) So maybe I wasn't ripped off as badly as first thought. Then I unwrapped a smaller capacity card (32 GB) which I bought locally, and loaded that into my card reader: the result was that it read 29 GB!
Do I still have to format the 32 GB card on my computer before transferring it to the camera?
Some is used up when the root folder is created, most disappears because disk drive and SD memory card manufacturers define a gigabyte as 1,000,000,000 decimal bytes, while everyone else including RAM memory manufacturers and Microsoft defines a gigabyte as 1000000000000000000000000000000 binary bytes (1,073,741,824 in decimal).
I checked the above website and it's all in German! Is there an English-language translation of that site?
Second, check out my last posting re verifying the actual capacity of the memory card by my card reader.
While it will be available from various English language websites, you never know what undesirable things might have been added, better to get the original from the original source, it has an English language option.
As I understand it, the bleeps come on when the memory is full [at 4GB from an earlier posting on this thread]. But as the memory has now been extended [by a factor of 8 for a 32 GB card], it should take a lot longer before the beeps are activated and not the (roughly) 30 mins operational time which I'm still experiencing.
Hope this makes sense ...
I case it is not clear, if you have loop recording set, most people use 3 or 5 minutes, the camera should record continuously with no beeping and loop around the card replacing the oldest video with new video.
If you have beeping due to memory issues then there is a card issue, either it is fake or it has got corrupted and needs formatting. Normally it should never get corrupted unless you remove it from the camera while it is being written to - turn the camera off before removing it.
You can also get beeping from the LDWS warning which most people keep turned off.
