3 Beeps
in 128gb the chances of a fake card are high if bought online
I did buy the card online because it looked like a bargain at $9! And I've been had, it seems!
Well, I won't be doing that again, that's for sure .... 🙁
yeah, ok, for $9 I wouldn't even bother testing it, you bought a fake, at least you only paid $9, plenty of people pay regular rates for their fakes
There are plenty of decent online sellers, but none of them sell 128 GB for $9, not sure they even sell 8GB for that so maybe you got a bargain if you convert it back to the 8GB card that it is! If you are buying online then it is worth having eBay or amazon protection as refunds are normally instant with no questions asked since the fake sellers want to keep their high feedback scores! Without that protection it is very risky.
Yeah rule number one. Buying anything electronic for 1/10 of it's regular price generally means it's a fake. Basically you paid the price of a 8GB card and someone put a 128GB sticker on it.
I imagine they just add a "12" sticker, just in front of the "8GB" one!
You won't believe this; but when I loaded the "supposedly" 128 GB card into my card reader, the on-screen icon (on my computer) logged it as 124 GB! (I somehow lost 4GB along the way somewhere ...!) So maybe I wasn't ripped off as badly as first thought. Then I unwrapped a smaller capacity card (32 GB) which I bought locally, and loaded that into my card reader: the result was that it read 29 GB!
Do I still have to format the 32 GB card on my computer before transferring it to the camera?
I think you will find that testing your 128GB card with h2testw.exe http://www.heise.de/download/h2testw.html will show it to be a fake card which only has 8 GB of actual memory...
PS Format it before testing.
I checked the above website and it's all in German! Is there an English-language translation of that site?
Second, check out my last posting re verifying the actual capacity of the memory card by my card reader.
that's just file system overheads, quite normal to show less than advertised capacity
But what still gets me is why the 3 beeps still sound with the higher-capacity card...! Theoretically, it should not even happen.
why do you say that?
As I understand it, the bleeps come on when the memory is full [at 4GB from an earlier posting on this thread]. But as the memory has now been extended [by a factor of 8 for a 32 GB card], it should take a lot longer before the beeps are activated and not the (roughly) 30 mins operational time which I'm still experiencing.
Hope this makes sense ...
do you have recycle on or off?
test the 32gb card with the h2testw software if it comes up good you can rule out the card, if the card is good and you're on the current firmware version then it can pretty much only point to a camera fault then I would think
OK - I'll give it a go and post the results on this thread ....
You won't believe this; but when I loaded the supposedly 128 GB card into my card reader, the on-screen icon (on my computer) logged it as 124 GB! (I somehow lost 4GB along the way somewhere ...!) So maybe I wasn't ripped off as badly as first thought. Then I unwrapped a smaller capacity card (32 GB) which I bought locally, and loaded that into my card reader: the result was that it read 29 GB!
Some is used up when the root folder is created, most disappears because disk drive and SD memory card manufacturers define a gigabyte as 1,000,000,000 decimal bytes, while everyone else including RAM memory manufacturers and Microsoft defines a gigabyte as 1000000000000000000000000000000 binary bytes (1,073,741,824 in decimal).
While it will be available from various English language websites, you never know what undesirable things might have been added, better to get the original from the original source, it has an English language option.
I case it is not clear, if you have loop recording set, most people use 3 or 5 minutes, the camera should record continuously with no beeping and loop around the card replacing the oldest video with new video.
If you have beeping due to memory issues then there is a card issue, either it is fake or it has got corrupted and needs formatting. Normally it should never get corrupted unless you remove it from the camera while it is being written to - turn the camera off before removing it.
You can also get beeping from the LDWS warning which most people keep turned off.
I had to format the new 32 GB card on my computer before the camera could record on it. It would not accept it otherwise. (Yep, tried it out last night .... ) Conclusion: all cards will have to be formatted first (takes about 1-2 seconds with a card reader).
