Vortex Radar
- Mar 26, 2014
- Seattle, Washington
- United States
So I've been wondering how much of a difference 60 fps makes over 30 fps and decided to test it out using a pair of A329's.
Online I've sometimes seen people say that shooting at a faster frame rate automatically implies less shutter speed, but that's not necessarily true. You do get smoother videos, sure, but that doesn't always lead to improved detail. In fact sometimes things like HDR work better.
Anyways, in this video I go into some camera theory, a bunch of testing between different frame rates, noticing when each frame rate has an advantage (like how 60 fps only has an advantage in lower light before you switch over to HDR), comparing different implementations of HDR, etc.
I also did a comparison of file sizes with different dashcams. Interestingly some show larger file sizes when you double up the frame rate which is what I'd normally expect, some keep the file sizes constant, and one, the A119 Mini 2, actually lowers (!) the file size when you jump to 60 fps.
