May I confirm if your card has been formatted to FAT32? A129 Plus Duo can support a 512GB memory card. But we don't recommend it.Hi, I also bought a 512GB Genuine Samsung EVO Select card at a discount on amazon but unfortunately it doesn't work with the Viofo A129 Duo Plus.
A question for VIOFO support, when are you planning to implement 512GB memory cards in this model? If you have a beta firmware, I will be happy to test and check it.
Thank you for your reply. I used 3 different programs to format the card to FAT32:May I confirm if your card has been formatted to FAT32? A129 Plus Duo can support a 512GB memory card. But we don't recommend it.
Hello,Thank you for your reply. I used 3 different programs to format the card to FAT32:
1. Acronis Disk Director 12.5,
2. GUIFormat2,
3. USBFormat.
In USBFormat I used the option - slow formatting, but it still did not bring the intended effect.
Every time I get the same error when I insert a memory card into the VIOFO A129 Plus Duo
Hello,
May I know how was the result using GUIFormat2? Can you please download the GUIFormat2 from this link and try again?
Is yours also a 512GB card?I'm having the same problem. Formatted using Smartdisk Fat32 tool and GUIFormat2 using the link you provided and my A129 Plus Duo will not recognize the card. The dashcam is upgraded to the latest 1.5 firmware too.
YesIs yours also a 512GB card?
Apparently the regular A129 duo supports it. Kind of odd the upgraded plus version does not.Which Viofo dash cams (if there are any that do) support 512GB?
I tested a SanDisk 1TB Extreme microSDXC formatted as FAT32 with the HP tool and it did not work. The camera went into a boot loop.I have a 1TB card coming soon I will test
Are there plans for the A129 Duo Plus to support 512GB cards?Is yours also a 512GB card?
A129 PLUS - No IR support? | A129 Plus / A129 Plus Duo | 17 |
Similar threads |
