I ran a "fuse box solution" charging test of the 70mai battery pack with a Thinkware U3000 2Ch dash camera connected to the 12V output connection port. My previous power consumption tests showed the Thinkware U3000 2Ch while recording in normal recording (driving) mode consumes on average 466 mA or 5.87 Watts @ 12.6V.
Comparing the "fuse box solution" charging cable "no load charging test" and this charging test with a dash camera load:
- 25%
- No Load: 15 mins 10 seconds
- Dash Camera Load: 16 mins 1 second
- 50%
- No Load: 29 mins 20 seconds
- Dash Camera Load: 30 mins 57 seconds
- 75%
- No Load: 43 mins 32 seconds
- Dash Camera Load: 45 mins 55 seconds
- 100%
- No Load: 58 mins 35 seconds
- Dash Camera Load: 61 mins 58 seconds
Time 07:22:11: Start of charging cycle by providing power "ACC In" power to the "Fuse Box Solution" charging cable.
Time 07:22:15 (0 minutes 4 seconds): The VCC and ACC out voltage levels are initially elevated to ACC = 13.62 / VCC 14.19V / Amps 0.410
The dash camera started to boot up and record at this point
Time 07:22:32 (0 minutes 21 seconds): The amp draw starts to ramp up to start charging the battery pack. ACC = 11.47V / VCC = 11.93V / Amps = 3.255
Please note the ACC and VCC output voltage levels initially drop to the mid 11V range when the battery charging cycle begins.
The dash camera continues to remain powered on and record despite the lowered voltage levels.
Time 07:23:11 (1 minute 0 seconds): ACC = 12.32V / VCC = 12.83V / Amps = 7.461
Time 07:38:12 (16 minutes 1 second): 70mai battery pack charge level reaches 25%. ACC = 13.27V / VCC 13.82V / Amps 8.572
Time 07:53:08 (30 minutes 57 seconds): 70mai battery pack charge level reaches 50%. ACC = 13.33V / VCC 13.89V / Amps 8.613
Time 08:08:06 (45 minutes 55 seconds): 70mai battery pack charge level reaches 75%. ACC = 13.45V / VCC 14.02V / Amps 8.689
Time 08:13:57 (51 minutes 46 seconds): 70mai battery pack charge level reaches 75+%. ACC = 13.58V / VCC 14.15V / Amps 8.757 (max amp draw of this charging cycle)
The amp draw will begin to slowly ramp down until the battery pack reaches its 100% charge level.
Time 08:24:09 (61 minutes 58 seconds): 70mai battery pack charge level reaches 100% charge level. ACC = 13.61V / VCC 14.18V / Amps 0.415
Most of the amp load of the dash camera is passed through to the DC power source (vehicle).
After reaching a 100% charge with a load on the battery pack, the battery pack will perform a "top off" charge cycle that lasts about 20 seconds. It ramps up the charging amps to a maximum in the 8.7 amp range and it then ramps down the charging amps as the charging cycle reaches its end. I only found one "top off" charge in the 23 minutes of video footage after the battery pack reached its initial 100% charge level.
