You have spent a fortune on a dash cam, yet you want to use a lower end $210 battery pack not optimally designed for the Viofo? I don't think this is wise. One of the risks is you won't know how long your dashcam lasts using parking sentinel mode. That's a headache!Hello everyone, has anyone of you installed this battery pack with a no-70mai dashcam?
As next week I'll ask for a professional installment of this battery pack with my Viofo A329 2CH.
I uderstood the dascham can be connected in 2 different ways to the battery pack:
1. Via 5v USB-C port
2. Via 12v output port + the HK4 specific cable
Which is in your opinion the best approach?
Thanks in advance for the help🙂
I think you know what I mean. A battery with a larger capacity which is easier to monitor. The 70 Mai battery is difficult to monitor just as I said and you know it. My battery was drained after this time. I had to choose a higher voltage cutoff after that. It shouldn't have happened but I need to jump it my battery. It was installed correctly. It doesn't last as long as I hoped (less than 20h parking monitor)What do you mean about batteries designed for Viofos? Viofo is developing their own brand of battery, but it's not available yet and currently none of the batteries are "designed" for Viofos even though they otherwise work just fine with them. I've run Viofos off of BBMC, 70mai, Blackvue, and Cellink batteries, not to mention non-dashcam battery packs and battery stations.
Voltage cutoff isn't a big concern with dashcam batteries. That feature is primarily designed for when you're powering off your vehicle battery and you want to cut off the dashcam before you drain the car battery voltage too far so you prevent yourself from having a dead battery and not being able to restart your car next time. With dedicated batteries, that doesn't matter. They charge while you drive and then when you park, they supply as much power as possible to your dashcam.
Sorry, no, I don't know what you mean. It's true that having an app with more granular battery info, regardless of whether or not that info is accurate, can be helpful, but in no way does that make it work better in any other meaningful way. I'm not sure what voltage regulation, for example, has anything to do with monitoring the battery capacity remaining. Usually when we talk about voltage regulation, it has to do with shutting off a dashcam when the vehicle battery drops below a certain point. Are you referring to something else?I think you know what I mean. A battery with a larger capacity which is easier to monitor. The 70 Mai battery is difficult to monitor just as I said and you know it. My battery was drained after this time. I had to choose a higher voltage cutoff after that. It shouldn't have happened but I need to jump it my battery. It was installed correctly. It doesn't last as long as I hoped (less than 20h parking monitor)
Your dashcam battery should only charge when the engine is on and it's being charged off the alternator and thus your car's starter battery is never being used to power the dashcam (or dashcam battery) while parked. That's the whole point.My battery dropped to a voltage low enough the car wouldn't start. I raised threshold voltage so the dash cam would shut off earlier
Will check. Thank youYour dashcam battery should only charge when the engine is on and it's being charged off the alternator and thus your car's starter battery is never being used to power the dashcam (or dashcam battery) while parked. That's the whole point.
You may have a wiring issue if your dashcam battery is draining the car battery to a point where your engine isn't starting. It may be a good idea to doublecheck things and ensure that the dashcam battery is not drawing power from your car battery while parked.
Battery hooked up correctly. You were right about voltage regulation setting as I misinterpreted how main battery lost power. I corrected my post to prevent misinformation and to promote clarity. Drain came from elsewhere. My battery died from a light left on so this agrees with what you said. Minor issue.Will check. Thank you
Glad you got that figured out!Battery hooked up correctly. You were right about voltage regulation setting as I misinterpreted how main battery lost power. Drain came from elsewhere. My battery died from a light left on so this agrees with what you said. Minor issue.
They also cost more too, lolI saw your video today. You said many of the same things I did here. On 70 Mai no Bluetooth monitoring of power usage. Just four blinking lights. Many higher end battery packs do.
Oh interesting. I hadn't done any measurements on the TriPro so I'm glad to hear your numbers.My 20+ hours agrees with your 23.5 hours before dash cam dies. I have been using 70 Mai battery pack on Tripro for 2-3 months.
I've only used it for 70mai dashcams since I'm always concerned about different communication protocols being used between brands and thus some brands of dashcams many not properly switch between driving and parking mode, so I tend to prefer the 3-wire parking mode option.I noticed that both you and I used hardwire cable and don't use USBC port on 70 Mai. Can that USBC port be used for anything?
Please test and find out. Love your videos. Very tech savvy!Glad you got that figured out!
I haven't done any testing to see if it'll output to both the 12v 3-wire cable and the USB port simultaneously in case you wanna do something like a separate USB powered WiFi hotspot or something, but it'd be easy enough for anyone to try and see.
What issues did you encounter?I have tested it at higher temp than 38C. It does have issues above that temp. I put it on a laptop chiller during summer months. I have had it installed since early June with no issues with the chiller installed.
Where did you buy your battery pack from? When I change the currency on 70mai's website to GBP I no longer see an option to buy it
70mai battery pack successfully delivered from German Amazon. £196 to the door.The only place I found was German Amazon. I've ordered one, hasn't arrived yet but can update when it does.
Make sure you don't expose it to high temp70mai battery pack successfully delivered from German Amazon. £196 to the door.
I don't think there's much risk of that in the UK. Its LiFePo4 and has protections built in though, is there a specific reason why you mention it?Make sure you don't expose it to high temp
