Well, I finally got my ProDriver and as expected, I was rather underwhelmed after having seen the other sample videos. The front camera was about the same or less quality as the generic $50 1080p single channel I currently use. Despite claiming 1080p, the generic is really only a 720p, as upping the recording resolution to 1080p results in only a couple hundred MB file size increase per 10 minute clip with no increase in image quality, just smaller OSD text. The ProDriver has the same file size regardless of whether it records in 720p or 1080p. My generic creates a 1.4gb mjpg file per 10 minutes of video, while the ProDriver creates a 225mb H264 file per 5 minutes of video and seems to have less detail. Media Player indicated a variable bit rate of around 6mb for the ProDriver, which I guess accounts for it's rather mediocre performance. The rear camera is even worse despite it also being 720p. File information indicated the video was 1280x720 24 fps mjpg, but it looked more like poorly sampled 640x480 with frequent glitching of the image. The front night time image is acceptable and is less susceptible to over exposure, but is also slightly less sensitive than the generic. Ironically, the daytime image seems to be over exposed. The left edge of the image is out of focus, similar to Tivan's videos, except his is on the right side. This leads me to believe that the sensor is not well centered with the lens and the overall image may also be slightly out of focus. It also came with a micro USB cable, presumably for connecting to a PC, but the camera only has mini USB interfaces.
I recorded the daytime video in 720p and night time in 1080p, but didn't see much difference. I'll compare the daytime 1080p between both cameras some more in the next few days, but I'm not expecting to see much improvement. Anyways, here are some sample still frames from all 3 videos if anyone wants to take a look before spending their hard earned money. The first image in each set is the generic 1080p camera, followed by the ProDriver front then back.
KuoH
You can see the left side focus problem in the following image comparison.
Here are some night time images. Notice the trailer truck on the left side waiting to cross is not as visible in the ProDriver image and also the car going up the on ramp on the right side. The colors are also not as saturated or accurate.
Here are some samples of the glitching that occurs every few seconds from the rear camera. Yes, I made sure the USB cable was firmly inserted in the front camera and the connector to the rear camera.
