- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
tried a different memory card?
I'm using a Lexar 633X 128 GB right now. The only other card I have is the much dreaded red and silver Sandisk Ultra in 64 GB. Doesn't hurt to try I guess.tried a different memory card?
the symptoms you describe sound like a power problem, assuming the charger you're using is up to spec it will be a camera problem, best to talk to whoever you bought it from about getting it replaced
It seems a power problem.the symptoms you describe sound like a power problem, assuming the charger you're using is up to spec it will be a camera problem, best to talk to whoever you bought it from about getting it replaced
We suggest to use the original cable and try to power by power bank to do testing.
Gearbest is consulting their product department to decide how to proceed.
I have send a PM to you, if gearbest can not offer a good solution, we can help to you also we'd like to check it further.Gearbest is consulting their product department to decide how to proceed.
i find i often have to press REC more than once to make it stop recording so i can get into the menu for setup. just have to wait for the flashing red dot at the top of the screen to go away and the camera to start beeping, then you can press menu to get into setup.I'm also having the same problem as AlexL about the device overheating. It seems that the sd card area gets hot. I have latest firmware 2.0 with new 128gb samsung evo plus micro sdxc. Recently purchased the Viofo A119. Also when pausing recording then pressing menu it either takes snapshot or freezes and therefore needs restarting. To gain access to the menu functions I have to press the menu button soon as the VIOFO logo starts up. Am I doing this right because I'm a new user to dash cams also this camera is for my dad for christmas and I'm making sure its working.
@viofo I don't know what's happening with the A119/A119S ....Tidal wave of defect complaints. Could it be just one batch of recently produced A119/A119S that all have problems because I never heard of so many problems when the cams were released. If this was about defective cars there would be a recall.My camera also heats a lot on high resolution settings, but if I use 720p not much heating on the camera, once i opened the camera I found that one of the capacitors was blown up, need a replacement...
https://dashcamtalk.com/forum/threa...gs-are-lost-cmos-battery-problem.26548/page-2
Does it reboot when powered through the cameras power port?Of course, I have the same problem. I'm using the GPS module and the extra wiring that was included to hardwire mine using an Add A Circuit fuse I had bought from O'Reily's. I also modified some of the settings. The LCD would begin flickering, then it begins the continuous rebooting loop. I'm going to adjust the settings to see if it corrects the problem.
