- Feb 6, 2016
- New England
- Viofo, GitUp
Not sure what your talking about. Never said any of that. I said tilt the board up 90 degrees. There is no need to completely remove the board from the camera. I have replaced a few caps on these cameras has never had to remove the board, splice any wires or solder anything on the wrong side. Unscrew the board, tilt it up (allows access to the rear of the board), unsolder the bad cap, cut the leads on the new caps to the proper length and solder them back into the same holes on the board. No shorts. No splices. No soldering the wrong side.It does look easy to attempt your simplified repair procedure except ...
I wouldn't recommend any Retailer telling customers to splice solder long leads or surface solder a weak joint on wrong-side in any device exposed to excessive vibrations and possible short circuit in a plastic housing running in Parking Mode over night without extra liability insurance. Always solder wired components on opposite side of circuit board for added strength and minimal wire exposure risk. I've found a few used DVRs with extremely bad solder joints, no need to inflate the issue.
just my observation, nothing personal.
