I'm off to Florida in September so could buy one while there, but a UK purchase would be better from a warranty perspective.
When will is be available in the UK and where from?
Many thanks!
things like LED too dim are subjective, keep in mind if they use did high brightness LED's it makes them easy to see during the day, and blinding at night, I'd think they would be unlikely to change something like this anyway, the A119 is certainly a step up from the A118
Spytec have been a dealer for a long time, I'm sure @viofo will confirm for you when they are online next
Actually according to the feedback from end users, we haven't heard much issues for A119, even I can say it is stable.Wow! Haven't been on here for a few weeks and the pages of threads suggest there are many issues with the A119?
Or can someone reassure me all is OK?
And also, best price and place to buy in the UK?
Many thanks!
Oooops!: https://www.amazon.co.uk/gp/B01HMZVYLY
I can not understand where there are 2 bad reviews for A119 on Amazon UK, both declared no or little improvement for night video quality compared to A118C.
What's holding me back is reading all these threads with all kinds of problems/queries.
If you are optimisticonly about 50% of the rest will be real review
That is probably the size of the box in comes in. Camera itself is about 8.25cm x 5.4cm x 3.8cm@spytec @viofo
Is the cam really...
Seems a little too large for what I want!
- Product Dimensions: 15.2 x 12.7 x 10.2 cm
i posted a bit of hopefully useful info in your other thread asking about your bmw and porsche. you won't find instructions much more detailed than that unless you're looking on forums for your specific vehicles, and even then it's hit and miss as it's provided by regular folks, not employees. i've never taken apart the dash on a cayman, and only worked on a small section of the dash in an older boxster. and the only bmw i've seen apart was an early 00's M3. but i've worked on enough different vehicles to have a decent idea of what to expect and what to avoid when installing additional electronics.Yes, I'm taking that into consideration. I guess what I'd like to see is a thread for potential buyers listing everything I need. For instance...
...You'll need the A119C; a micro SD card with the following spec...; a hardwire kit with the following spec...; here is a link to how to hard wire your dash cam...; a copy of the A119C instructions is linked to here...; if not buying the GPS mount you should consider a right angle USB connector cable with the following spec...; if you prefer black 3M windscreen tape the dimensions are...
These are all things I'm having to look into so I don't just buy the cam and then find I can't mount it how I'd like.
I don't think there is a fake version in the market at present.@viofo Maybe it's a fake? It's £11 cheaper than Boblov's and doesn't have "VIOFO" on the casing.
