A119S v2 gps module problem
dakota
Spain
Hello!
I am Javi, a new user of A119S V2 violet with GPS module and the CPL
I am from Badalona (Spain) and my English is a bit of a pain, so I hope you excuse me since I use a translator to correct mistakes
Since I installed the camera in my car (Citroen C4) I have problems with the GPS module, it takes a lot of time to pick up the signal (pass the speed indicator from red to green) and during the driving it loses the signal even in very clear areas
I am with the support of the seller indicating the problem, since I do not see normal that it takes almost 10 minutes or that I lose the signal without reason. At first I thought it was a bad connection.
I pass a photo of a capture with the car parked after a trip of about 15 minutes in which at no time frame the speed.
There is a symbol to the right of an antenna so I understand that there is communication with the module and the problem is that it has not "hooked" with the necessary satellites
Regards
Javi.
FIXED! the problem are the cristal...
I moved the camera to the area where there is no athermal protection and the camera is working properly
This is something that should warn those who buy the GPS module and have this type of glass
