Jeremy Wong
- Apr 14, 2015
- Kuala Lumpur
- Malaysia
- Viofo A119, Viofo A119S, Xiaomi Mijia, 360 J511C, etc
Check your pin on the gps module. Maybe one of the pin got stuck.
Checked all the pins and all is fine...
Let me understand.... your A119S doesn't seem to work with your GPS module? You say you will try to see if the GPS is ok with your A119. The only concern I have is.... the GPS module which DVR was it delivered with? Because I was led to believe that the earlier GPS modules that were supplied with the A119 will not work with the A119S Maybe you mixed up the modules without realizing
Bill said the GPS mount works on both A119 and A119S... My A119 GPS mount has a white label on it while the A119S is without any label... So I didn't get it mixed up... 🙂
Update - found the culprit that caused the GPS unable to connect, ddpai mini2 dashcam that was next to the GPS mount...
