Yes, I did reformat the card prior to testing this FW version
No, it's not the same version. It has moved on since then.Is this the same beta version you were testing weeks ago when you said "the g-sensor in parking mode is much improved"?
Format the card on PC as FAT32 before copying the original firmware from Viofo.I have the same problem I am unable to revert back. I tried everything.
After another reformat, the camera worked fine for a couple of days. Then today I found it beeping constantly in parking mode - not recording. When I turned on the engine it switched to parking mode and recorded all the way home. Then at home the beeping resumed with no recording in parking mode.I installed the beta FW yesterday (V1.9T7 - Build20191120).
I did a soft reset to default in camera, plus hard reset button. Card is Viofo 64GB U3, formatted in-camera. Loop duration set to 3 minutes. Low-bitrate parking mode enabled.
Issues so far:
- On two occasions, the camera completely shut down when I turned off the ignition. I had HK3 connected to the GPS mount, and red LEDs in the HK3 showed it was capable of supplying power to the camera. Since connecting HK3 directly to the camera, the camera no longer shuts off completely by itself.
- I suspect loop recording started this afternoon. I had a lot of double-beeps, all whilst driving. Usually a pair of double-beeps every minute or two. I also had a sequence of 6No double beeps, and another of 4No double-beeps.
I'm using V1.9T2 with low bitrate parking mode and the g-sensor goes off every time I close my door (while the camera is in parking mode). G-sesnor left at default of high. Didn't do this on V1.9. Also, my power button work as it did before. I power down the camera every time I park in my garage, before I shut off the car.
Did you manually default the cameras settings, then press the reset button on the side of the camera after the update?
This beta FW V1.9T7 does seem to behave differently to past versions regarding FW updates. I copied the FWA129.bin file for V1.50 to my card and booted the camera, but it did not read the file or modify the FW.
Can only format exFat in windows 10 x64 , SD is 128GB
that won't do it, it sticks to the standards and will only format the card exFAT
Oops - sorry for the bad advicethat won't do it, it sticks to the standards and will only format the card exFAT
better to just format the card in the camera, it will format the card FAT32
it's the ideal program for resetting cards, you might have been thinking of FAT32formatter/GUIformat which is the normal go to program for formatting large cards to FAT32, good for cameras that can't format the cards natively, for a camera that can though best to just format the card in the cameraOops - sorry for the bad advice![]()
I think maybe it just doesn't format the card, I have formatted a card and then found the files still on it but was not sure if it was my fault or the cameras fault...Just checked - my 64GB U3 card that was formatted in-camera is exFAT, so the A129 does not format large cards as FAT32, at least with this current FW version
In the past I have used FAT32 Formatter which has worked with large cards.
