I'm not accepting your reality as you are assuming what the numbers quoted are specifying when they don't actual make any mention of what the figure is meant to indicate, and you don't actually know, you have just assumed what it means, you're putting words in their mouths, I'm not suggesting that that's how things should be where people are left to assume or guess or whatever, it's confusing and I get that
I know what you say and this is full of... nonsens.
My reality is the physics reality. The FOV advertised should be the real FOV. As customer, I don't care what sensor+lens they used, but I do care about the real FOV and what they advertise IS NOT THE REAL FOV. And, to speak same language, the advertised FOV should be the HORIZONTAL one, not diagonal. We don't see in diagonals...
And, as possible customer, when I want to document me about a camera for buying and I read specs like in the picture below, should I guess what they wanted to mean with 140 degrees wide viewing angle? What you would understand reading such of specification?
Making a parallel with photo... if I buy a lens with 50 mm focal I know it has 50 mm focal (on full frame sensor@35 mm film) and I also know that on a crop sensor (for example Canon, or Nikon, or Olympus) the crop factor will multiply the focal and I will have an equivalent focal of 50xcrop factor (lower FOV). But in the case of dashcam I'm not forced to know (and it's completely useless for me) the focal@field of the lens and the crop factor of the sensor. Maybe would be better if they would advertise these things. But, instead, they advertise absolutely adopted/nonsens values (in romanian we have the expression "they took them out from the belly").
The world doesn't change just because you want it to and only fools and visionaries even bother to try. Neither get results and visionaries are mighty rare.
Wow, you're so "spiritual", but you're not smart at all when you're trying to offend me. Because I only feel offended by people smarter than me.
You forgot a category, dreamers. I am a dreamer and sometimes dreams come true.
PS: The discussion was civilized until you came... maybe would be better to keep it so.
